Adding another SPI device along side the Codec shield
I am trying to record audio data from the Codec chip to an SD card @ 8 kHz using the shield + Arduino Uno(not sure if it is possible - Just an experiment). I tried connecting an SD card to the SPI interface with a different CS pin. The moment I connect anything to the clock pin (D13 of the arduino) apart from the codec shield, it generates a lot of static noise. I assumed that the SPI pins are held at a high impedance state unless the CS pin is low.
