multiplexing the SPI line (codec data line)
here is an example for multiplexing the SPI line. it takes advantage of the level shifter/buffer on the codec shield board. the EN pin on the codecshield needs to be connected to D7 for it to work. you will also need the sinewave lookup table in the codecshield library.
basically, D7 is set as an output in the setup routine. then, in the interrupt, it is used to disable the buffer, and the SPI can be used to send data some other place (just random junk in this example). the interrupt flag must be cleared before reinstating the the buffer.
sine_generator.pde
guest openmusiclabs 7.7.11
unsigned int mod0_value = 0;
unsigned int mod1_value = 0;
// PROGMEM stores the values in the program memory
// it is automatically included with AudioCodec.h
PROGMEM prog_int16_t sinewave[] = {
// this file is stored in AudioCodec.h and is a 1024 value
unsigned int location; // lookup table value location
DDRD |= 0x80;// setup a control pin for SPI buffer
// toggle spi
PORTD &= ~(0x80); // turn off SPI
SPDR = left_out; // send data to some other device
while(!(SPSR & (1<<SPIF))); // clear interrupt flag & transfer complete
PORTD |= 0x80; // turn spi back on
int temp1;
int temp2;
temp1 = pgm_read_word_near(sinewave + location);
// use upper byte of mod1 value to set the rate
MultiSU16X16toH16(temp2, temp1, mod0_value);
// our sinewave is now in temp2
left_out = temp2; // put sinusoid out on left channel
right_out = -temp2; // put inverted version out on right chanel
reti(); // dont forget to return from the interrupt
