Control two parameters via Serial communication
4 posts · 21252 views
by terr » Mon Dec 09, 2013 01:15 UTC
Hi all.
I was wondering would it be possible to control the two parameters (potentiometers) : frequency and amplitude of the sin wave generator (or any two parameters from ) simultaneously via serial communication. I was hoping to try something the same as this post
http://forums.openmusiclabs.com/viewtopic.php?f=21&t=301
but using both mod1_value and mod0_value.
I have a bit of code already to try and break up byte into to two 4 bits and so control the two parameters. I will then write some code in Processing to sent a byte of data something similar to this A127B127 where the int values are between 0 and 127.
I just don't know what changes are needed in the ISR function to allow me to change both parameters. Any help would be greatly appreciated. Thanks
sine_generator.pde
 guest openmusiclabs 7.7.11
//strings to store the values of upper and lower end of the incoming string
String slider1;
String slider2;
//store characters of incoming string
String readString ;
unsigned int mod0_value = 0;
unsigned int mod1_value = 0;
// PROGMEM stores the values in the program memory
// it is automatically included with AudioCodec.h
PROGMEM  prog_int16_t sinewave[]  = {
  // this file is stored in AudioCodec.h and is a 1024 value
unsigned int location; // lookup table value location
  while (1){ // reduces clock jitter
    while (Serial.available()) {
      if (Serial.available()>0) {
        char c = Serial.read();
        readString += c;
    if (readString.length() >0) {
      // get int values
      slider1 =   readString.substring(1,3);
      slider2 =   readString.substring(5,7);
      int n1=0;
      int n2=0;
      //convert String to int
      char firstSlider[3];
      slider1.toCharArray(firstSlider, sizeof(firstSlider));
      n1=atoi(firstSlider);
      char secondSlider[3];
      slider2.toCharArray(secondSlider, sizeof(secondSlider));
      n2=atoi(secondSlider);
      if(readString.charAt(0)=='A'){
        mod0_value=n1;
      if(readString.charAt(4)=='B'){
       mod1_value=n2;
  int temp1;
  int temp2;
  temp1 = pgm_read_word_near(sinewave + location);
  // use upper byte of mod1 value to set the rate
  MultiSU16X16toH16(temp2, temp1, mod0_value);
  // our sinewave is now in temp2
  left_out = temp2; // put sinusoid out on left channel
  right_out = -temp2; // put inverted version out on right chanel
  reti(); // dont forget to return from the interrupt
Re: Control two parameters via Serial communication
by guest » Mon Dec 09, 2013 01:45 UTC
there are 2 ways of doing this. i will show the easier one first, and if that doesnt work, we can dig deeper. the main issue is that the all of the codecshield libraries are written as interrupt driven, and the serial libarary needs interrupts as well.
  Serial.begin(9600); // initialize serial port
  if (Serial.available()) {
   int input  = Serial.read();
   // collect and create your variable completely before doing this last step
   cli; // turn off interrupts before transferring the number
   mod1_value = input;
   sei; // turn interrupts back on
by terr » Tue Dec 17, 2013 17:18 UTC
Hi I have tried the following code but can't get it to change to values for frequency and volume. I don't know if its where we have the cli() and sei() methods thats the problem or not. Or if its a case that the code works but the pots are overwriting the values that are passed to it The code has changed a bit but it is still breaking up a byte. Making the pots redundant would be OK as we just want to change the values via serial.
sine_generator.pde
//char array
char command[4];
//byte to hold serial.read()
byte b;
int index=0;
  readCommand();
  setValues();
void readCommand(){
  while(Serial.available()>0){
    if(index<4){
      b=Serial.read();
      command[index]=b;
      index++;
    else if(index>=4){
      Serial.println(command);
      index=0;
void setValues(){
  int k1=command[1] - '0';
  int k2=command[2] - '0';
  int k3=command[3] - '0';
  int k=(k1*100)+(k2*10)+k3;
  switch(command[0]){
  case 'X':
    cli();
    mod0_value = k;
    sei();
    break;
  case 'Y':
    cli();
    mod1_value = k;
    sei();
    break;
  int temp1;
  int temp2;
by guest » Tue Dec 17, 2013 18:45 UTC
yes, the adc is overwriting the values. comment out that line, and set ADCS 0 at the beginning.
it will be difficult to use both the serial line and the adc to set the same value. you might be able to do something that looks for changes on the ADC, and only then does the ADC change the value. basically, store the last value, and compare it to the current value, and if the difference is greater than 10 or so, then change. there will be some noise on the ADC, so even if the knob isnt moving, the value will change a bit.
