replace mod1_value with serial input from MAX MSP
I'd appreciate some pointers to alter the sine_generator example so that mod1_value is sent from a Max MSP patch using the serial object in Max and Serial.read in Arduino. I suspect my lack of success has to do with
" // use upper byte of mod1 value to set the rate ".
I put Serial.begin(9600); in the setup
and trying
if (Serial.available() > 0)
// read the oldest byte in the serial buffer:
incomingByte = Serial.read();
mod1_value = (incomingByte * 4);
as an attempt to replace mod1_value with the incoming serial values.
The Max patch is basically the Dimmer example in Arduino:
http://arduino.cc/en/Tutorial/Dimmer
sketch
sine_generator.pde
guest openmusiclabs 7.7.11
int incomingByte = 100;
unsigned int mod0_value = 0;
unsigned int mod1_value = 0;
// PROGMEM stores the values in the program memory
// it is automatically included with AudioCodec.h
PROGMEM prog_int16_t sinewave[] = {
// this file is stored in AudioCodec.h and is a 1024 value
unsigned int location; // lookup table value location
int temp1;
int temp2;
temp1 = pgm_read_word_near(sinewave + location);
MultiSU16X16toH16(temp2, temp1, mod0_value);
// our sinewave is now in temp2
left_out = temp2; // put sinusoid out on left channel
right_out = -temp2; // put inverted version out on right chanel
reti(); // dont forget to return from the interrupt
and trying
sketch
sine_generator.pde
int temp1;
int temp2;
