Board index › Products › MICrODEC › Software
audioint4 program listing
8 posts · 11567 views
by mcanulty » Fri May 21, 2010 06:20 UTC
this is no longer accurate, see final post
; current programs and their memory locations
; code switch memory address/data bits/channels - function
; $0200 = position 07 = 18b/16b/stereo - delay - pot controlled (3ms - 3s)
; $0400 = position 06 = 16b/16b/stereo - delay - pot controlled (0s - .7s)
; $0600 = position 05 = 16b/16b/mono - vco with vca
; $0800 = position 04 = 16b/16b/stereo - upsweep - pot controlled
; $0a00 = position 03 = 16b/16b/stereo - reverser
; $0c00 = position 02 = 16b/16b/stereo - up/down sweep
; $0e00 = position 01 = 16b/16b/stereo - delay - rotary encoder controlled
; $1000 = position 00 = 16b/16b/mono - reverb
; $1200 = position 15 = 16b/16b/mono - fullwave rectifier
; $1400 = position 14 = 16b/16b/mono - gated reverser
; $1600 = position 13 = 16b/16b/mono - envelope stripper as vca on rampwave
; $1800 = position 12 = 16b/16b/mono - ring modulator
; $1a00 = position 11 = 16b/16b/mono - sampler - pot controlled playback speed
; $1c00 = position 10 = 16b/16b/mono - 16 voice chorus
; $1e00 = position 09 = 16b/16b/mono - flanger
; $2000 = position 08 = 16b/16b/mono - sampler - rotary encoder controlled playback speed
Re: audioint4 program listing
by guest » Fri May 21, 2010 07:02 UTC
those listings are probably wrong
the ones to pay attention to
are the ones next to the .org statements
at the bottom of the main file
i didnt update the comment listings
by guest » Thu Jun 10, 2010 06:52 UTC
this all brings up a good question
what 16 programs should the microdec come preloaded with
we should probably nail this down soon
so we can get those polished for release
by mcanulty » Mon Aug 23, 2010 09:11 UTC
by waterman » Fri Sep 17, 2010 18:29 UTC
I am assembling the program & have a couple of lookup tables.(I can't find them, anyway)..
sinewave-16b-512s.asm
tone_chart-16b.asm
Are these posted?
Thanks
by guest » Fri Sep 17, 2010 20:34 UTC
thanks for the catch
ill get them up on the wiki shortly
they will be posted with the stock functions
there is also the full bundle with them in it
linked off the documentation section of the wiki
http://wiki.openmusiclabs.com/wiki/MICr ... rodec1.zip
by fairyanna » Mon Jan 05, 2015 08:01 UTC
I think I would be interested in this. Also, been meaning to ask,
I have the modern device's USB breakout board, with the FT232R chip,
will that work for programming the microdec?
by guest » Mon Jan 05, 2015 19:15 UTC
that usb to serial converter should work for programming a microdec that has the arduino bootloader on it (all the ones sold from oml had it).
