point to codec shield buffer
Hi ,
I am trying to convert signed int samples from the codec to unsigned char ( 8 bit ) for libltc
I'm using in the interupt but i think its too slow..
unsigned char samples = (right_in >> 8) & 0xff;
ltc_decoder_write (decoder, &samples, 1, 0);
I was looking at the Mods available in your codec but i'm not sure how to use them ?
how do I get the library / sketch to use MultiSU16X8toL16 ?
it would save time ? the libltc function i'm using requires a pointer to 'unsigned 8 bit char' samples buffer..
I tried,
int temp1;
int temp2;
MultiSU16X8toL16(temp1,temp2, &right_in); // can i use this multiplyer to get 8bit unsigned char ?
ltc_decoder_write (decoder, &temp1, 1, 0);
but i get errors...
I tried,
int temp1;
int temp2;
but i get errors...
