Board index › Products › rePatcher
rePatcher not working with pd patch in Extended
9 posts · 89848 views
by arne » Tue Nov 04, 2014 18:44 UTC
Hi
Im trying to get my rePatcher to connect to pd with the repatcher_test2 patch with Pd-Extended.
This is what it says:
[comport]: available serial ports:
1 /dev/tty.Bluetooth-PDA-Sync
4 /dev/tty.usbserial-A7006R1z
But when I chose 4 as port number and turn on open/close, start/stop nothing happens.
I´m on OSX 10.6.8
There is also no sound when I move the faders.
Which maxpat should i try if its not working?
arne
Re: rePatcher not working with pd patch in Extended
by guest » Tue Nov 04, 2014 21:17 UTC
1. did the arduino code load properly?
2. which arduino board are you using?
3. do the faders in the patch move when you rotate the knobs?
i dont know what maxpat is, could you explain? also, perhaps give it a shot with just the repatcher object, and a slider bar attached to one of the knob outputs.
by arne » Tue Nov 04, 2014 21:35 UTC
Hi
1. Im not sure what that means.
2. arduino duemilanove with ATmega328
3. No
A Maxpatch, sorry.
I will try with repatcher object tomorrow.
Thank you
arne
by guest » Tue Nov 04, 2014 22:59 UTC
ok, there is a thing called maxpat, so i just wanted to check. there is a max patch on the wiki, so feel free to give that a go.
1. there is an arduino sketch that needs to be loaded onto the arduino before the repatcher can work. do you have the arduino IDE on your computer?
http://arduino.cc/en/main/software
by arne » Wed Nov 05, 2014 15:31 UTC
Hi
1. What sketch is this and how is this done.. sorry for the noob questions.
And yes I have installed the Arduino program.
arne
by guest » Wed Nov 05, 2014 18:20 UTC
ok, here is the link to the sketch:
http://wiki.openmusiclabs.com/wiki/Repa ... atcher.pde
in case that doesnt work, its the first link on the main repatcher page:
http://wiki.openmusiclabs.com/wiki/Repatcher
so just save that file, and open it in ardiuno. then upload the code by clicking on the forward arrow icon at the top of arduino (there is probably also a file->upload drop down menu). make sure the correct board and comport are selected in the "tools" drop down menu.
by arne » Wed Nov 05, 2014 19:08 UTC
Hello
It all works now!
Thank you so much!
arne
(Is there any more places where people have made pathes for the repatcher?)
by guest » Wed Nov 05, 2014 20:19 UTC
awesome to hear it works!
i dont know of any patch repositories. here is a macro to use it with reaktor:
http://www.native-instruments.com/en/co ... show/8001/
by arne » Wed Nov 05, 2014 20:48 UTC
Thank you!
a
