Additional potentimeters
4 posts · 19609 views
by rompelstilchen » Tue Sep 17, 2013 20:09 UTC
hello,
i saw the demo page
but i want to know if it is possible to add potentiometers to the a.c. shield
or is it possible to send custom command data to the shield from arduino
it is to create a stompbox, so i need more pot's
(no, i am not interested in the stomp shield cos it does pwm output and i dont want that)
thx
Re: Additional potentimeters
by guest » Wed Sep 18, 2013 05:17 UTC
the hardware allows for 2 more pots, but i will have to check if there is code written to access them. i think i may have done that at some point, but cant remember. so it is possible, but might take a bit of fixing the library.
what do you mean by sending custom command data? it can accept external serial, but both the SPI and I2C buses are used by the codec, so data can not come in that way.
by guest » Wed Sep 18, 2013 05:19 UTC
also, sorry for our forums not working quite right. if it says there was an error, there actually wasnt, and you can just go back to the previous page. reloading the page puts another post in. hopefully we will get this fixed.
by irag12 » Tue Sep 16, 2014 10:27 UTC
you should be able to do that, although first check the write rate of your SD card. fill up a buffer, and time how long it takes to write it to the SD card. or even better, write 10 buffers worth, and see how long that takes. im suspecting there is some downtime between buffers. you can use millis() to measure this time. my concern is that data will come in faster than you can write it out.
