Board index › Products › MICrODEC › MICrODEC General Discussion
Input
5 posts · 9567 views
Input
by koalo » Sun Jun 16, 2013 17:41 UTC
you have written that the input can be used as microphone, instrument and line level input, but I haven't found any more information about that. I thought these three need different impedances. Is there any way to switch this?
Greetings,
Florian
Re: Input
by guest » Mon Jun 17, 2013 16:44 UTC
the input of the microdec is 500k, which is good for instruments. for microphones and line level it is not ideal, but it doesnt effect the sound that much. it has gain variable from 1 to 50, which is good enough to amplify most microphones and guitars.
Re: Input
by koalo » Tue Jun 18, 2013 21:21 UTC
Thank you!
So you would say the input is optimal for guitars and a DI box or something else would not make it better?
Re: Input
by guest » Wed Jun 19, 2013 19:16 UTC
yes, the input is good for guitars, and a DI box wouldnt help any. it basically has the same input stage as most effects pedals.
Re: Input
by koalo » Mon Jun 24, 2013 13:22 UTC
