Adding a Tap Tempo
Hey folks!
Here is a basic tap tempo program you can run on the Audio Codec Shield with Maple. Just attach a momentary contact switch between +3.3V and GPIO pin 17 of the audioCodecShield. That's J1, pin 3 and J2, pin 4.
the code works up to a point- after 4 taps, it requires a timeout before it will start reading taps again.
tap tempo based on
sine_generator.pde (MAPLE)
guest openmusiclabs 7.13.11
// note the Maple library
#include <AudioCodec_Maple.h>
// note the uint16 typedef, there is no "unsigned int16" type
int16 left_in = 0; // in from codec (LINE_IN)
int16 right_in = 0;
int16 left_out = 0; // out to codec (HP_OUT)
int16 right_out = 0;
uint16 mod0_value = 0;
uint16 mod1_value = 0;
// note the int16, ints are 32b in Maple land
int16 sinewave[] __FLASH__ = {
// this file is stored in AudioCodec_Maple.h and is a 1024 value
uint16 location; // lookup table value location
// Tap Tempo stuff
const int digitalInputPin = 17;
#define NUMBER_OF_TAPS 4
int32 gateTime[NUMBER_OF_TAPS] = {0};
int32 gateTimer=0; // time since last tick
int32 dbTimer=0; // debounce
int32 activeTimer=0; // how long until tap sequence is abandoned
int activeTimerMax=44100; // how long until tap sequence re-started
int32 gateNumber=0; // how many taps accumulated so far
int dbTimerMax= 1000; // noise debounce interval
int32 tapSequenceTimer=0;
int16 tapTempo(void);
#define TAP_IDLE 0
#define TAP_ACTIVE 1
int16 tapState = TAP_IDLE;
// periodic beep sound
int32 beepCountdown=0;
int32 beepCountdownMax = 22050;
int32 beepLen=1000;
void setup()
SerialUSB.end(); // usb conflicts with the codec in this mode
// a different operating mode which allows both
// is in the works
// setup codec and microcontroller registers
AudioCodec_init(); // call this last if you are setting up other things
// for tap tempo switch
pinMode(digitalInputPin, INPUT_PULLDOWN);
void AudioCodec_interrupt()
int16 temp1;
temp1 = sinewave[location];
// use upper byte of mod1 value to set the rate
tapTempo();
// since it returns a 32bit value it needs to be scaled with ">> 16"
temp1 = (temp1 * mod0_value) >> 16;
left_out = temp1; // put sinusoid out on left channel
right_out = 0;
if((++beepCountdown)>=beepCountdownMax)
beepCountdown = 0;
int sineEnv;
if(beepCountdown<beepLen)
sineEnv=1;
} else
sineEnv=0;
left_out = left_out * sineEnv;
int v = digitalRead(digitalInputPin);
if(dbTimer>0) // there was a trigger so wait a bit for clearing
if(v==0){ // only decrement if button is not pressed
dbTimer--;
switch(tapState)
case TAP_IDLE:
if( (v==1) && (dbTimer==0) ) // only accept click if first in a while
dbTimer = dbTimerMax;
activeTimer = activeTimerMax;
gateNumber = 0;
gateTime[gateNumber] = 0;
tapSequenceTimer = 0;
tapState = TAP_ACTIVE;
break;
case TAP_ACTIVE:
tapSequenceTimer++; // keep track of time when tap is active
if((--activeTimer)<=0) // haven't tapped for a long time?
if(gateNumber<3){
gateNumber = gateNumber + 1;
gateTime[gateNumber] = tapSequenceTimer;
// now do tempo calc
int32 i,tapAcc=0;
for(i=1;i<=gateNumber;i++)
tapAcc += gateTime[i] - gateTime[i-1];
beepCountdownMax = tapAcc / gateNumber;
beepCountdown = 0;
break;
