putting code in loop() on arduino
here is a quick tutorial if you want to put any code in the loop() part of your arduino code.
IMPORTANT: Download the latest libraries from the wiki if you got them before 8.16.12. there was a mistake in the original header files that would cause problems in the main loop() under some very, very rare conditions. but, its best to not have to wonder, so please redownload them.
first off, all of the examples in the AudioCodec library are written to process the data in the interrupt service routine (ISR). this has the advantage of being faster and lower jitter, but is also a bit more difficult to write. for things that don't have to happen on a strict timing schedule, and are very low processing overhead, they can fit into the main loop() part of the code. what this does, is allows these functions to run in the background, and not interfere with the audio processing that happens in the ISR. as an example of how to do this, here is a piece of code that will allow the pitch of the sine generator to be controlled by a serial connection:
you should be able to open the arduino serial monitor, and send characters to the arduino, and change pitch.
Things to NOTE:
1. NAKED is removed from the ISR setup. [ISR(TIMER1_COMPA_vect)] - this allows all of the data used in the interrupt to get pushed on the stack. its more time consuming, but its imposible to run anything in loop() if you dont do this.
2. reti() is no longer called at the end of the ISR. when you get rid of NAKED, this is automatically done for you.
3. Serial.begin() is called before AudioCodec_init() - this is just precautionary, but AudioCodec_init disables some things inside the arduino that might be used by some functions, and cause them to not initialize properly.
4. delay() and millis() can NOT be used. - AudioCodec_init disables TIMER0 to reduce clock jitter and conflicting interrupts.
5. everything in loop() is nested under the while(1) - this makes it process faster and reduce jitter.
sine_generator.pde
guest openmusiclabs 7.7.11
#define ADCS 1 // use both ADCs
unsigned int mod0_value = 0;
unsigned int mod1_value = 0;
// PROGMEM stores the values in the program memory
// it is automatically included with AudioCodec.h
PROGMEM prog_int16_t sinewave[] = {
// this file is stored in AudioCodec.h and is a 1024 value
unsigned int location; // lookup table value location
// call other setup stuff first
while (1) {
if (Serial.available() > 0) {
// read the oldest byte in the serial buffer:
mod1_value = Serial.read() << 8;
ISR(TIMER1_COMPA_vect) { // changed to store registers (NAKED removed)
int temp1;
int temp2;
temp1 = pgm_read_word_near(sinewave + location);
// use upper byte of mod1 value to set the rate
MultiSU16X16toH16(temp2, temp1, mod0_value);
// our sinewave is now in temp2
left_out = temp2; // put sinusoid out on left channel
right_out = -temp2; // put inverted version out on right chanel
AudioCodec_ADC(&mod0_value);
// reti(); // reti NOT included when NAKED is removed
}you should be able to open the arduino serial monitor, and send characters to the arduino, and change pitch.
Things to NOTE:
