Guitar Effects Algorithms
8 posts · 12258 views
by diydsp » Tue Jul 24, 2012 02:03 UTC
This is a dual tremelo that I've been having fun with:
RingAndTrem05.zip (1.7 KiB)
Each knob controls one tremelo. Explore the combinations of slow and fast settings.
Re: Guitar Effects Algorithms
by diydsp » Tue Jul 24, 2012 02:08 UTC
This one is a digital divide-by-1.5x sound with a noise gate. In goes 999 Hz, out comes 666 Hz.... under a certain set of conditions... usually guitar sounds progress through a sequence of dominant tones and choosing different pickups and tone settings on the guitar leads to different envelopes.
It's kind of like setting up a guitar signal to drive a divide-by-3 counter, except that the counter is clocked on both up-going and down-going transitions of the input waveform. There are some long, drawn-out reasons why you might want to do this and I'll get to them at another time.. For now, just enjoy it as a sound :)
DividingDistortion01.zip (2.3 KiB)
frequency divider, divided-by-1.5
by diydsp » Tue Jul 24, 2012 02:26 UTC
Although this one is named "Wah05," it's not actually a wah-wah pedal yet, just the filter part, with a distortion module inline following the filter. Mod 1 = Distortion, Mod 0 = filter frequency...
stick around and we'll modify this code to be a wah pedal with just a few adjustments.
Wah05.zip (1.9 KiB)
Mod1= Distortion Depth, Mod2=Wah/Band-Pass filter center frequency, implemented as a state-variable filter (SVF).
p.s. I'm developing these programs with a prototype Aristocrat pedal, but all of this will work identically for any audio system built from an Audio Codec Shield and a Maple. Arduino can not handle this type of stuff at full sample rate and 16-bits like Maple can.
by diydsp » Tue Jul 24, 2012 03:03 UTC
....and in case anyone wants an audio demo... here's Wah05, hand-controlling mod0 (of "Fc", center frequency) on the Audio Codec Shield:
Wah05.mp3.zip (217.4 KiB)
9 Second loop of two open chords playing through medium-Q bandpass filter sweeping up and down + light clipping distortion.
by diydsp » Tue Jul 24, 2012 03:15 UTC
...all while we're at it, I'd like to include the frequency spectrum of this simple program... you can see how the frequency hops up and down as I twist the knob super fast. you can also see the distortion at the beginning of the second half as a ghost image of overtones, slightly above the fundamentals :)
Frequency Spectrum plot of the 9 second Wah05 demo audio above.
by clee » Wed Aug 15, 2012 20:18 UTC
What fun! Thanks for the code and spectrum.
by diydsp » Tue Aug 28, 2012 00:00 UTC
Thanks, clee!
Here's another effect I've been playing with lately. It's guest's pitch-shifter with a sequencer driving the pitch change. The pitch-sequence is stored inside the patch. You'll see have I have about 5 different ones in there; they're easy to change.
mod1 = sequencer speed
mod0 = general pitch range (same as guest's pitch-shifter!)
demo audio: http://soundcloud.com/diydsp/spaceyloops-with-the
Spectral representation of the what the sequenced pitch-shifter does do a guitar signal
Note: this program was modified to include the sequencer at the Providence Maker Faire 2012 while at a booth next to a whole bunch of gameboy street performers who played inside with a portable amp. They were rocking the whole time, providing a great, inspiring atmosphere and taught me some of the nuances of the root-minor third-tonic sequence!
// ArpeggPitch02 -
// mod0 = overall pitch
// mod1 =
//based on Open Music Lab's GuestPitch01
/* Pitch Shifter loosely based on Open Music Lab's miCrODEC pitch shifter */
// -no interpolation between points yet
// -two taps move through the buffer at the same rate
// -tap amplitudes have triangle overlap windows
// -MOD1 controls amount of pitch shift
#define ADCS 2 // only 1 ADC used here -> MOD0
#include <AudioCodec_Maple.h>
// -MOD0 is divided into 21 regions that are each a different pitch multiplier
// -step size 320 is 1/1 ratio, 160 is 1/2 or octave-down
// -the step array represents a series of intervals that are from just intonation tuning
uint32 step[] = {120,135,150,160,180,200,225,
                 240,270,300,320,360,400,450,
                 480,540,600,640,720,800,900};
uint32 step[39]={
  80,  85,  90,  95, 101, 107, 113, 120,
 127, 135, 143, 151, 160, 170, 180, 190,
 202, 214, 227, 240, 254, 269, 285, 302,
 320, 339, 360, 381, 404, 428, 453, 480,
 509, 539, 571, 605, 641, 679, 719
int16 left_in, right_in, left_out, right_out;
uint16 mod0_value = 0,mod1_value=0;
#define SIZE 2048 // buffer size is limited by microcontroller SRAM size
int16 buffer[SIZE];
uint32 location = 0; // buffer location to read/write from
uint32 tap_count = 0;
uint32 tap0_pos,tap1_pos;
int32 tap0_amp,tap1_amp;
int16 pitch_shifted;
// arpeggiator code
// bigger numbers are slower
//uint16 countDownMax=5000;int16 sequence[] = {0,2,4,2,0,2,4,7};int16 sequenceLen = 8;
//uint16 countDownMax=1000;int16 sequence[] = {0,4,0,5};int16 sequenceLen = 4;
uint16 countDownMax=1000;int16 sequence[] = {5,5,5,2,2,2,0,0};int16 sequenceLen = 8;
//uint16 countDownMax=1000;int16 sequence[] = {1,0,1,0, 2,0,2,0, 4,0,4,0, 7,0,6,0};int16 sequenceLen = 16;
//uint16 countDownMax=1300;int16 sequence[] = {7,0,0,7, 0,0, 7,-1};int16 sequenceLen = 8;
uint16 countDownVal=100,sequenceStep=0;
int sequenceVal=0;
  SerialUSB.end();
  AudioCodec_init();
  //nvic_irq_disable(NVIC_USB_LP_CAN_RX0);
void loop() {  while (1);  }   // reduce clock jitter
// timer4_ch1 interrupt routine - all data processed here
void AudioCodec_interrupt() {
  left_in = left_in * 8;   // scale input volume up by 18dB
  AudioCodec_ADC(&mod0_value,&mod1_value);
  // Arpeggiator Sequencer ------------------------
  countDownVal     = countDownVal - 1;
  if(countDownVal == 0){
    countDownVal   = countDownMax;
    // advance sequencer
    sequenceStep     = sequenceStep + 1;
    if(sequenceStep >= sequenceLen){
      sequenceStep   = 0;
    // Mod1 controls speed of arpeggiation
    countDownMax = 10 + ( (0xffff^mod1_value) >> 4);
    sequenceVal  = sequence[sequenceStep];
  // Pitch-Scaler ----------------------------------
  // Knob 0 selects pitch steps
  int n = 0;
  while (mod0_value > n) {
    n = n + 0x10000/21;      // 21 is the size of the step[] array
  n = n*21/0x10000;
  n = n + sequenceVal;  // add arpeggiator's pitch sequencer value
  if (n > 20) {
    //n = 20;     // option 1. Peak at max pitch
    n = n - 7;    // option 2. Roll back one octave from target
  tap_count = tap_count + step[n];
  int frac = tap_count%320;
  tap0_pos = (tap_count/320)%SIZE;
  tap1_pos = (tap0_pos + SIZE/2)%SIZE;
  // make the tap_amp's zero at the location and count up to SIZE on both sides
  // this for overlapping to hide the discontinuity the taps move across at the buffer's head location
  if (tap0_pos >= location) {
    if ((tap0_pos - location) <= SIZE/2) {
      tap0_amp = (tap0_pos - location);
    } else {
      tap0_amp = (SIZE - tap0_pos + location);
  } else {
    if ((location - tap0_pos) <= SIZE/2) {
      tap0_amp = (location - tap0_pos);
    } else {
      tap0_amp = (SIZE - location + tap0_pos);
  tap1_amp = SIZE/2 - tap0_amp;
  pitch_shifted = (tap0_amp*buffer[tap0_pos] + tap0_amp*buffer[(tap0_pos+1)%SIZE]
                 + tap1_amp*buffer[tap1_pos] + tap1_amp*buffer[(tap1_pos+1)%SIZE])/SIZE/2;
  pitch_shifted *= 2;  // scale volume to hear a little more easily
  // bit crush
  //uint16 numberOfBits = mod1_value>>12;
  //uint16 mask = 0xffff<< numberOfBits;
  //pitch_shifted = pitch_shifted & (0x8000|mask);
  left_out = pitch_shifted;  // send wet val to left
  right_out = left_in;       // send dry val to right
  // store value for next time
  buffer[location++] = left_in;
  if (location >= SIZE)    location = 0;
Sample and Hold and Bit Crusher
by diydsp » Fri Oct 12, 2012 02:56 UTC
Here's a little program I've been working on. It does two Lo-Fi effects: A BitCrusher and a Sample and Hold. One reduces information in the time domain and the other lessens dynamic range by creating an increased noise floor. If you twirl the knobs, you get some nice timbres... this would be good with an LFO :) or envelope follower :)
// SampleAndHoldAndBitCrush03 (diydsp)
// mod0 = BitCrusher amount
// mod1 = Sample and Hold frequency
#define ADCS 2
uint16 prev_left_in_mag=0;
int16 countDownVal=100;
int16 BitCrush(int16 inVal);
int16 SampleAndHold(int16 inVal);
SerialUSB.end();
AudioCodec_init();
while (1);
int32 inputFilt=0;
uint16 SampHoldOut=0;
// Main Processing Chain
SampHoldOut = SampleAndHold(left_in);
left_out = BitCrush(SampHoldOut);
static int16 outVal = 0; // keep local to this function
if(countDownVal <= 0){
// Mod1 controls interval
countDownMax = 1 + ( (0xffff^mod1_value) >> 8);
outVal = inVal;
return outVal;
// bit crush
uint16 numberOfBits = mod0_value>>12;
uint16 andVal = (0x8000|mask);
int16 outVal = inVal & andVal;
return outVal;
