by Hjorten » Fri Jul 20, 2012 22:21 UTC
I went with the thread cutting screws but it seems almost impossible to screw them into the channels since there are no "tracks" for them to fit into. I tried screwing them in quite hard, but I also don't want to risk the head to lose its shape.
Any tips how to get the screws in properly?
Yeah, I tried the torx head screws too, and have the same problem there.
by guest » Sat Jul 21, 2012 06:02 UTC
the screws are a bit tricky
the best way to get them in
is to first make sure that they are going in straight
if they start going in crooked
they will never get it
then tighten it up until it gets tough to turn
and back then back the screw out
and blow on the hole to clear it
then go in again
and repeat until its fully in
if it is still giving a bit of trouble
put a drop of oil into the hole
by Hjorten » Sat Jul 21, 2012 09:58 UTC
Okay, I'll give that a shot!
by Hjorten » Sat Jul 21, 2012 12:23 UTC
I found it a lot easier to not have the pcb in place when I screwed the screws. And I found a better driver than the one I used at first.
by guest » Sat Jul 21, 2012 19:49 UTC
both very good suggestions
did it all work out?
by Hjorten » Tue Jul 24, 2012 13:42 UTC
Yeah, it worked out perfectly. Just spent ten minutes playing around with it, and I thought it was just a minute or two, heh.
