Recording and Analyze
2 posts · 4248 views
by asmadi » Sun Feb 19, 2012 11:03 UTC
Hi guys,
I want to doing a simple project to record the sound and analyze it with a simple formula (x*x). Where x is equal a realtime sound. I'm just MOD the board to suite using with microphone. I open the 'microphone.pde' and try it and success!. Only, the code for record the sound and pass data through. Just, somebody have some idea how I want to start to analyzed the sound without pass data through?
My requirement:
Sampling Freq = 22050Hz (16-bit)
Frame size or maybe buffer size= 1024 (this frame size for analyze using a simple formula, x*x)
so for 1 seconds i will have 22050 data point and approximately 21 frame (22050/1024 = 21.5).
I hope i will get some idea to try.. ;) Thank You
Re: Recording and Analyze
by guest » Sun Feb 19, 2012 19:14 UTC
to create a buffer in memory
take a look at the exmple fixed_delay
// create a delay buffer in memory
#define SIZE 800 // buffer size is limited by microcontroller SRAM size
int delaymem[SIZE]; // 800 positions x 2 bytes = 1600 bytes of SRAM
unsigned int location = 0; // buffer location to read/write from
there is a limit to the size of memory in the arduino
about 800 samples is the max
then you increment the sample counter in the ISR routine
to change to 22ksps you can do the following at the top
#define SAMPLE_RATE 22 // 22.05Khz
