Simplest possible example
3 posts · 4765 views
by rascalmicro » Mon Aug 15, 2011 13:47 UTC
Some code I wrote/modified-- feel free to use it for anything.
I think this is the simplest possible code that I can come up with based on Mark's Arduino code-- the two knobs are just volume controls for the left and right channels.
// even though the function is mono, the codec requires stereo data
unsigned int mod0_value = 0;
unsigned int mod1_value = 0;
  MultiSU16X16toH16(left_out, left_in, mod0_value);
  MultiSU16X16toH16(right_out, right_in, mod1_value);
  reti(); // dont forget to return from the interrupt
Also, here are a couple lines of Python that I wrote to generate 1024-entry lookup tables.
As it is, the first line just maps the values 0-1024 to the square of itself (x**2), but you could replace the x**2 with any other mathematical expression.
lookup = [x**2 for x in range (0, 1024)]
f = open('lookup.inc', 'w')
for line in lookup:
    f.write(str(line) + ',\n')
f.close()
Re: Simplest possible example
by guest » Tue Aug 16, 2011 02:09 UTC
the script will be handy
ive been adding commas by hand
at the end of exel files i create
by mcanulty » Tue Aug 16, 2011 04:03 UTC
A bit of sad programming poetry! I guess I've got to work on a video, but I'd like to play with some of the code later tonight or tomorrow. It's nice having new activity on the forum :)
